- Joined
- Oct 26, 2010
- Messages
- 3,247
- Reaction score
- 17
- Location
- Leeds
- Year of Your Van(s)
- 1971
- Van Type
- Panel
I'm nearly ready to start putting my engine back together but before I do that I have to order a few bits and pieces. So I need your advice on a few bits.
I am running a 1641TP with a single 34 carb. I don't know much about engines (before stripping mine down I didn't know a cam from a crank!) so be nice and bare with me :lol:
1) turns out my cam was the point of failure (see here for the pics) so I needs to get me a new one. But what do I replace it with? I've done a lot of reading on this site and the Engle 100 or Scat c25 look like the advisories other than stock. But what benefit can I expect from the non-standard? Oh and 3 or 4 stud, what's the difference? I've noticed that some oil pumps are designed for 3 stud.. eh? How does that one work?
2) I've been advised to go full flow. My understanding of why to do this is that the type 1 engine has no form of oil filter, meaning we have to change oil more frequently. Putting in full flow allows for the addition of a filter which should not only extend the time between changes and oil capacity, but overall engine health should be improved. Am I getting close? Instead of having the case tapped I have been looking at the cheaper options, either CSP full flow adaptor or a maxi oil pump. What do you reckon? Bear in mind I have a '72 and am not sure that the items on the cbperformance site will clear the engine support bar. If I get a new oil pump with dual outlets I don't need any other kit, right? But if I go for the CSP option I need to get a new pump cover with a single outlet, too?
3) What is the bellow-type thing that sits under the push rods on the right (when looking in the engine bay) that has a linkage to the flaps in the fan housing? Whatever it is, mine looks pretty darn crusty! Going to have a go at cleaning it up, but have a feeling it will need replacing. Couldn't find a reference to this thing in my manual so can someone let me know what it is and what its purpose is please?
Cheers,
George
Cheers,
George
