clyde
Can anyone help.
Im currently running a 1600SP, but have a 1600TP from a Beetle that i am going to rebuild and fit in my bus. Its got the required bolt holes as its a later multi use case but my question concerns the tin.
The Beetle engine came complete with all its tin but which pieces of tin will i have to change to get the engine into my bus.
Also ive got some of those T3 style cool tins knocking around the garage some place and was wondering if they are worth fitting or not. (they are sold as up dates to T1/T2 cooling)
I imagine the rear piece will need to be changed? If so can i use the rear tin that is currently on my bus? I cant look at my bus at the moment for comparison as im getting ready to go back to sea and the bus is safely locked away.
Cheers folks. Be prepared for some engine cc, cams, fuel pump and oil pump etc questions.
