smudge
Built by Ben at TDC vw in the states............
First of all this motor in its current build spec will NOT zoom you down the Pod to beat the rest!.Its been built for everyday use with a little omph if you need to get out of trouble
Compression is 8:1 rockers stock German 1.1 crank VW German forged
new Case tapped for Full flow.
NEW heads..Pistons and barrels...
40 Solex Carbs again new....
26mm oil pump.
Empi breather kit,MSD 5,CB 3.5psi fuel pump all to come with the Engine.
With a few simple upgrades this engine could easily pump out more power ie Ratio rockers,change the solex for webers etc...
But if your looking for a good STRONG Motor then this may be for you.200 miles without getting hot,no smoke just happy motoring sat at 70 on the way home from port.
Come and test drive it as its still in my bus(i wont let you floor it though as it needs a few more miles on it yet!).If you are Happy ill help you take it out and put the kettle on
Price;;£1800 ovno
location;SWINDON WILTSHIRE SN2 5JE
PS took my mate out in this the other night and he shat his pants! :lol:
26mm oil pump.
Price;;£1800 ovno
