Right..
Took the bus in yesterday for its MOT and there is a few things i`m unsure about! :?:
Firstly it failed on a couple of things that i can sort: :idea:
Welding to front chassis rail :?
Welding to rear n/s jacking point. :?
But here are the things i`m uncertain of how to fix and why..??? :?:
Right first he said that he wants the anti roll bar nuts swapped for nylocks and i wouldn`t have thought that would be a problem and also the top shock absorber mounts changed to nylocks but he also said that he wanted the bottom mounts changed too!! But i`m sure these aren`t standard thread so how can i get around that??
Also my brakes were apparantly imbalanced by 80% and that i needed a new wheel cylinder up front! But it runs discs up front so does this mean a new caliper?
And last but not least it was pulled up on play in the steering column!! Now it seems as though the steering box is fine but i think there must be a bearing of some kind in the top of the steering column? Is there? And how do i get it out? It`s in pieces as we speak! :idea:
Thanks in advance for all the help!! :!:
Alex :wink:
Alex :wink:
