Fingers crossed!!
maddog
Oct 5, 2006
685
Hampshire
Im hoping to receive my new engine this Fri.
Ive already fitted my CSP brake conversion kit but ive still got plenty to do this weekend:-
Remove engine & g/box.
Clean engine bay.
Fit new g/box, clutch cable, oil cooler, oil filter, starter, engine & exhaust.
Fabricate engine support bar.
Fit & wire up fuel pump.
Re-wire dyno to alternator.
Wire up gauges.
Hopefully thats it but no doubt other little things will appear too!
Interior can wait hahahaha............
Will keep you posted :D
Not much then :shock: good luck dude and may the way of the early bay be with you :mrgreen:
Woohoo!!! New engine came today!!!
Gonna have a few ciders to celebrate the 14 months ive been waiting for it.
Pics tomorrow :D
My new baby :D
Scampi said:
That is one sweet looking engine dude!
Whats the spec?
Thanks mate but that goes to a top engine builder :wink:
Ive got some fabricating to sort out....i will post more pics but today i was just to dirty to handle camera haha......
Should be out on the strip soon tho.... :D
Specs as far as i remember!
94mm stroker barrels/pistons
044 heads ported and polished - matching inlet manifolds
Tefflon buttons
42.....37 ss valves
Weber 44's
FK10 cam
82mm crankshaft 4340 chromoly etc..
1:4:1 rockers
H beam con rods
Bolt on rockers
Electronic ignition
Fully merged exhaust
Phatboy muffler
Full flowed with FRAM oil filter and fan assisted oil cooler
Electric fuel pump with regulator
Empi oil pump
Kennedy stage II clutch
1.5 ltr deep sump
009 dizzy and blue coil
Sorry thats all i can think of at mo as i have the spec sheet to hand
Oh and the bhp is very healthy :wink:
Sounds like a sweet donk there. Could you do me a favour and take a pic ( when you get your hands clean)of your fan assisted oil cooler please? It sounds like an interesting piece of kit. Not that the rest of the motor is dull by any means.
Thanks,
David
Bit late but heres some pics.....
Firstly the old engine in the bus....
Engine removed.......
Once the engine was removed and gearbox lowered i noticed the brake pipe connecting the 2 rear flexi-hoses was rusty.
Pipe replaced and brakes bled.
Next up was to start on the wiring, so a trip to the shop for some extra wire and connectors was needed.
Rained off for some of the day, i drew out the wiring so once i got started on it id know exactly what was what.
Mean while i decided to clean up the chassis rails and treat them as surface rust had occured.
Probably the most difficult part of the job was to work out how i was going to fabricate an engine support bar as the original one doesnt fit.
This will get sorted later on in the week and then work can continue!
Justin & Mutley said:
You don't do anything by halves, do you?
It's looking fantastic, maybe you could post some video once it's all running so we can all share your joy! 8)
I'll try to video it once running..........if not, im hoping to get into the club at Bugjam :wink:
