Fireflex / Firetec - what's best?
Mike F
Oct 5, 2006
1,446
31
Hinderwell, North Yorkshire
I've been meaning to put one of the fire systems in the van and found the May 2007 C&C with the fireflex article.
Trouble is I can't find anything on the internet as to how to buy.
Searching for the other systemt mentioned, Firetec, was not much better.
What do people here have fitted? If I want to buy and fit asap where do I go?
Got a respose from Firetec this morning
We offer bulk discount for kits to clubs* as follows:
1-4 units no discount
5-10 units 20%
11-20 units 30%
> 20 units 40%
discount on optional items (switches and Chafegard etc), by negotiation.
* a club must have a club name, address (which is often that of the
secretary), named secretary and contact telephone number.
FIRETEC CT AXIAL system for VW T2 Campers
Fire Monitoring Systems manufacture an automatic fire suppression systems for use in VW T2 campers. These are basically especially configured Firetec CT Axial systems.
The Firetec CT equipment is described in http://www.FiretecUK.com
Specifications for use in VW T2 campers.
Cylinder: model E5. 270mm x 88mm diameter. 1.5 litres aluminium.
Tube: 3.50 metres 6.2 x 4.0 heat sensitive REACTON.
Valve: Stainless steel Axial valve with easy top-up external Schrader,
pressure gauge, and tube connections.
Bracket: light transport bracket, with countersunk bolt kit.
Extinguishant: special mix, 9% AFFF, non corrosive foam.
Installation options:
Upright on LH chassis leg, horizontally on LH chassis leg or horizontally under engine compartment ‘roof’.
Buyer must state if under roof configuration is required.
Instructions:
Standard CT instructions with extra page specifically for VW T2 campers, included.
Requires good general DIY skills, but no special tools.
Prices:
As above: .. .. .. .. .. .. £135.00
As above but with dry powder instead of AFFF foam: .. £145.00
Options:
Full length stainless steel Chafegard spiral protection to tube: add £ 18.00
Built-in switch + dash LED for system status display
Green permanently-on, or red-on when discharged:
Choose green or red. Does not include wires. add £ 20.00
Availability:
Within 10 days from receipt of order.
Installation:
Straight forward for reasonably competent DIY person, or,
by arrangement with Firetec engineer. n.b. this saves carriage cost.
Payment terms:
With order please.
Invoice sent on request stating your equipment and serial number.
Carriage. (under hazardous goods regulations) add £ 15.00
ALL FIGURES ABOVE SUBJECT TO VAT.
is £135 a good price? it seems steep?
I thought these systems were just an extinguisher attached to a temperature sensitive hose that melts at a certain temp and releases the foam? or is it more complicated than that?
Just paid £159 so that's a good price!
Have had too many disasters over the last couple of weeks so I am not taking chances any more whatever the cost.
Thats exactly all it is but thats the going rate to be honest. I like the fact that he will give discount on bulk purchases (or at least I would if I had the dosh), If i could find another 19 peeps then thats a 40% reduction £81 :D
Just a quick update on this thread.
I eventually found that Coolair stock Fireflex and collected one this morning, £160 for the larger bottle - didn't see any point in cutting back at this point!
I fitted the unit very quickly, maybe 45 minutes - with the following observations...
the C&C article clearly uses the smaller bottle, which is much easier to fit in. The large upright just about squeezes in just inside the engine bay on the left but someone else may prefer to check the flat instead of upright unit.
not enough cable ties provided, wish I'd followed slammedkustom's advice and got a box. That's tomorrow's job before I drive it!
no problem fitting at all - the tube loops easily and I get the feeling that the whole engine bay is covered. Well worth the money I'd say.
