Just copy and pasted this from the late bay, from their last deal in jan 2012
QUOTATION / INFORMATION.
FIRETEC CT AXIAL system for VW T2 Campers
Fire Monitoring Systems manufacture an automatic fire suppression system for use in VW campers.
These are especially configured Firetec CT Axial systems.
Firetec CT equipment is described in general in http://www.FiretecUK.com" onclick="window.open(this.href);return false;
SPECIFICATIONS for use in VW T2 campers.
Cylinder: model B1. 340mm x 85mm diameter. 1.25 litres aluminium.
Tube: 3.50 metres 6.2 x 4.0 heat sensitive REACTON R80.
Valve: Stainless steel Firetec Axial valve with easy top-up external Schrader, safety pressure gauge, and tube connections.
Bracket: Transport bracket with countersunk bolt kit.
Extinguishant (default): special mix, 9% AFFF, non corrosive foam.
INSTALLATION options:
Upright on LH chassis leg, horizontally on LH chassis leg or horizontally under engine compartment ‘roof’.
XXXXX You must tell us if you require the ‘under the engine compartment ceiling’ orientation. XXXXX.
FITTING INSTRUCTIONS:
Standard CT instructions with extra page specifically for VW T1/ T2 campers included.
Requires good general DIY skills, but no special tools.
PRICES:
As above: .. .. .. .. .. .. £158.00 *
As above but with dry powder instead of AFFF foam: .. £168.00 *
As above but with gasses: all gasses available. Price depends on gas specified.
Note, dry powder is the best medium for extinguishing fires but is an irritant, can solidify inside the cylinder due to engine vibration and becomes a corrosive glue when damp, AFFF foam cools and wets and does not cause corrosion, but is only as half as good as powder, and gasses should not be used in road vehicles as they are dissipated by fan draught and road wind.
OPTIONS:
Full length stainless steel Chafegard spiral protection to tube: add £20.00
Reacton R 108 tube for use with ‘hot’ Porsche or Subaru engine campers. No extra charge.
Built-in SWITCH for dash LED system status display etc:
Switches are be used to complete or break external circuits.
For use with Green permanently-on LED, or Red-on-when-discharged LED:
Choose switch for green or red LED. Does not include wires or actual LED. add £20.00
4 wire Changeover switches also available. Add £25.00
Wire and LED not supplied. For LED use RS components or CPC etc.
AVAILABILITY:
Currently dispatched within 7 days from receipt of order.
INSTALLATION:
Straight forward for reasonably competent DIY person, or, by arrangement with Firetec engineer. n.b. depending on where you are this can be as much as £200 ! (just for installation), although it does save carriage cost.
WARRANTY:
12 months free replacement of complete system kit unless damaged externally.
Note: failure to read and follow instructions often leads to external damage to the tube.
PAYMENT TERMS:
With order please.
When ordering, it is ESSENTIAL that you supply the following information:
1. a daytime delivery address, (preferably a business address).
2. your actual name (not your user name).
3. your actual home address (for your receipt)
4. a telephone number for the delivery address. Goods will NOT be despatched without this.
5. the orientation for the unit (where you want to install it in the T2). No delivery without this.
6. a cheque (payable to Fire Monitoring Systems Ltd), or arrange to pay by wire transfer.
A Pro-Forma Invoice will be sent to you stating your equipment spec and it’s unique serial number.
DELIVERY. under hazardous goods regulations. Fire extinguishers are classified as hazardous!
Very few parcel carriers will transport fire extinguishers. The GPO certainly does not.
For delivery add £15.00 per consignment per business address regardless of quantity.
Haz goods transport to individuals is surcharged by £10, so to avoid this please use a day time business address for delivery.
Timed deliveries are not available under haz goods arrangements.
ALL FIGURES ABOVE SUBJECT TO VAT.
* less discounts passed to VW clubs or associations.
n.b. Do not repack this equipment for distribution. Proper packing is critical to it’s intact arrival. We can deliver additional units directly to individual addresses. The Haz Goods delivery charge is £15.00 per business delivery address regardless of quantity to be delivered to that address.
Questions, e.g. advantages of different extinguishing agents, etc:
E-mail or call 0845 500 9339
Firetec CT systems for VW T2 campers.
Prices 2011.
1.25 litre aluminium cylinder with CT Stainless steel head manifold, support bracket, safety shrouded pressure indicating gauge, easy top-up Schrader valve with steel cap, with blind port for pressure switch if specified and fitting instructions.
Default system:
With 1.05 kgs 9% AFFF foam and 3.5 metres 6.2 / 4.0mm Reacton 80 (red) heat sensitive tube.
For clock 6 horizontal or vertical installations: .. .. £158.00
For clock 3 or 9 under ceiling versions: .. .. .. £158.00
As default but with 1.05 kgs Grade 70 dry powder: .. .. £168.00
As default but with special gasses: .. .. .. .. £ POA
Options
As above but with built-in single acting pressure sensitive switch: add £20.00
As above but with built-in double acting changeover type switch: add £25.00
As above but with full length HD Chafegard .. .. .. add £20.00
Freezol antifreeze with AFFF systems for -8C or lower usage. .. add £5.00
Larger systems, e.g. 2 .0 / 2.25 litres etc. .. .. .. £ POA
All deliveries: add £15.00
All figures subject to VAT at rate applying.
Manufactured by Fire Monitoring Systems Ltd. Biggarts House, Beattock. Scotland. DG10 9RH.
tel: 0845 500 9339 email:
[email protected] www.FiretecUK.com
BULK DISCOUNTS: offered to clubs for single orders of
1 to 4 systems: no discount offered.
5 to 9 systems: 25%
10 to 19 systems: 33%
>19 systems: 40%
n.b. discounts do NOT apply to Optional extras i.e. switches, Chafegard and/or antifreeze.
With the discount works out something like this
£94.80 for unit
£25 for double switch
£20 Chaff Guard
£22 P&P ( but this can be shared if muliti orders to one Delivery)
All above plus the dreaded VAT 20%
Total = £194.16
I'm having the same but with Antifreeze so mine is £200.16..!!
Just thought I'd post this lot for those wondering estimated prices etc,
BUT IM NOT SAYING THESE WILL BE OUR PRICES JUST WHAT I'VE COPIED
