Fitting JK tow bar help
wanderlust
Nov 1, 2006
672
SARF EAST LONDON
Does anyone have a JK tow bar fitted to their bus? Bought one this week but it doesn't appear to fit. The uprights fitted into the chassis with no problems but the bar that connects to the uprights doesn't fit. The bolt holes are about 2cm out of alignment. Everything is stock on the bus.
If anyone has one fitted are they able to measure the how far apart the bolt holes are one the bar that runs between the uprights?
Have you tried loose fitting the entire bar then go round after tightening the nuts n bolts afterwards.
Rich
Tight as in touching it???
Actually once it's all bolted up there may be a 2 or 3 mm gap I reckon???
Does that sound right??
