So the weather was top banana today so I started on the drivers door scrapers. Followed Saraj's guide as much as possible
as shown below (I thought I would add my own account and pictures).
Started off with the side runner nearest the lock. Mine was quite stiff to wiggle out of the top clip but it did pull down and
out following a little side wiggle.
Then undid the window carrier and dropped the glass to the bottom of the door - You have to do this as it's the only way to
get it low enough to extract the scrapers.
Next I started pulling down the felt channel that runs around the top and down the back edge. On mine the original retention clips
were still there so i was careful to prise them down and keep them. They just slot into holes within the door frame passing though
the chrome/aluminium trim on the outside.
You can see above the slot hole that the clips go into.
Ok, 1/4 light slider bar next. I did as Saraj said and undid the top screw that retains the whole top of the 1/4 light frame followed by the M10 screw at
the bottom through the larger bodywork hole.
Then attempted that apparent tilt and slide method for the slider bar - Bastard was pretty rigid in there and would not move. Forgot to mention I slid the
glass sitting in the bottom of the door, as far as it would go toward the lock end (rear) so that it would not foul the slider bar. In the end I undid the other screw at the top of the vertical slider bar (Normally hidden by the felt). This loosens it from the main 1/4 light frame.
This post is startin to get big so I'll pop onto a new one. :mrgreen: :mrgreen:
