- Joined
- Apr 2, 2007
- Messages
- 478
- Reaction score
- 26
- Location
- Berkshire
- Year of Your Van(s)
- 1972
- Van Type
- Danbury
Hi All,
Wanted to ask all your opinions on another dilemma I'm facing with my first resto.
Having removed the front windscreen and rubber seal, I was pleased to find that after scraping off all the bubbly paint that there were no holes.
However the lower channel is very pitted:
Of course I could cut this all out and weld in either some repair strips or replace the top section of the front panel - however this is a lot of work and will probably result in some distortion of the original front panel etc. Plus I'd like to try and keep 'some' of the original van!? :roll:
Instead, I'm considering borrowing a sandblaster and cleaning this all up really good before treating it all and putting a skim of filler across it to smooth it all back out, prior to painting and refitting the windscreen with a new seal.
Is this a good or bad idea? Will blasting it really get all the corrosion out or will I just be delaying the inevitable need to cut it all out and replace with new a year or two later?
![DSCF0568.jpg](https://proxy.imagearchive.com/323/323332425f183ab634e1c235ffbf24af.jpg)
