A bit of a rant from me, and hopefully will avoid others having the same frustration. I recently purchased an off-the-shelf hard line to pipe the fuel hose through the front engine tinware, as I’d previously been using a small barb, which wasn’t really ideal. What I received differed somewhat to the catalogue pictures offered. Whilst the pipe vaguely follows the correct directions, the use of large radius bends that weren’t at the right angles meant the part needed a bit of tweaking to make it fit without rubbing anything. Add to that, the ends had been crudely cut with a hacksaw and not de-burred - an accident waiting to happen if not rectified.
Now I appreciate this is a cheap part, but I bought it because I don’t own any pipe benders, so selling something that is pre-bent but requires tweaking kind of defeats the object...
In my case, the vendor offered a refund if I returned it, so I can’t fault that. But they were keen to point out that this is how they all come from the supplier. I have suggested that they should put photos of the actual item on their webpage, or at least a description of the actual work required to make the part fit, but whether that will be heeded or not remains to be seen. I can’t comment as to whether all the usual sources purchase from the same supplier.
For anyone thinking of purchasing one, my advice would be to buy a bender and some tube, and do it yourself.
