Fuel sender unit
Skyguy
Sep 23, 2012
135
Poole
Hi guys,
Is it possible to use a bettle fuel sender unit in my bus as they both have the same bolt hole pattern and the bettle one is cheaper and maybe more reliable?
Thanks in advance.
If they have the same part number, you could probably interchange them. If they don't, there's a reason why VW made two different models.
If you mean the lever arm type sender, I don't think they work with the bus gauge.
The genuine VDO ones for bus are best, but they've gone up a bit since I bought mine in 2019 for £70!
I saw something on one of the many FB groups where someone had done this and it worked but can't remember where I saw it and you really shouldn't believe everything you read on FB🤣🤣
