Gear issue???
ratty1959
Nov 25, 2013
252
Oxford
Hi, i have a 2110cc mounted to a 6rib type 4 box, bug tech shifter, all works amazing! Apart from its started sticking in 4th gear? Until i stop then it seems to release?
Any ideas!??
Cheers jai
Has it got plenty of oil in it? Could be a couple of things
Worn synchro, damaged hub or hub sleeve.
Oil is topped up mate, its odd as it wasn't like it at all last month (last use) but i did have a play with the shifter as it can be a tad stiff, have had it stuck in 2nd gear a couple of years ago but that was down to a loose bolt on the bug-tech but that is now sorted!
Most likely your 3rd/4th gear hub have fractured, its a common problem, can be repaired pm me.
(here same problem: https://itinerant-air-cooled.com/viewtopic.php?f=47&t=7320)
