Yep and with a bigger/high perf engine you normally run remote cooling so the fan speed @ RPM is less an issue. And you have more torque so it just makes sense to lower the revs...Quieter, more economical...more fun ![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Humphrey said:Yep and with a bigger/high perf engine you normally run remote cooling so the fan speed @ RPM is less an issue. And you have more torque so it just makes sense to lower the revs...Quieter, more economical...more fun![]()
sparkywig said:Humphrey said:Yep and with a bigger/high perf engine you normally run remote cooling so the fan speed @ RPM is less an issue. And you have more torque so it just makes sense to lower the revs...Quieter, more economical...more fun![]()
Sorry, remote coolers only cool the oil which has a minimal effect on overall engine cooling.
You still need the fan to turn at optimum speed to cool the engine. Air from the fanhousing is directed over the cylinder heads and barrels by the tinware, that's why they're called air-cooled engines.
Alex VW Heritage said:The freeway flyers you can get built in an earlybay 002 box so no messing around just a straight swap with a brand new gearbox.
Marriedblonde said:Alex VW Heritage said:The freeway flyers you can get built in an earlybay 002 box so no messing around just a straight swap with a brand new gearbox.
I really need, ok want, one of these but is there really a 17 week wait? Not sure i fancy having all my money tied up with nothing to show for it for so long :-(
http://www.vwheritage.com/vw_spares_Rancho-T2-Freeway-Flyer-002-Gearbox-Inc" onclick="window.open(this.href);return false;£350-S-Chg-AC300002FF_act_shop.product_pID_71864255_lang_EN_country_GB.htm?crumbStartPage=1
Marriedblonde said:I take it Pete will take my box and replace the internals? Which means I will be without my bus :-( hence I was hoping if I could get a replacement it would mean I could just swap them over meaning I can keep using it.
