Dirty Harry
Engine back in attached oilcooler,oilfilter,thermo switch (for the fan of the oilcooler),2 oldshool VDO gauges (pressure, temperature) and my Ampco top cilinder oiler.
Very clean engine bay - do you actually drive it
Dirty Harry said:Engine back in attached oilcooler,oilfilter,thermo switch (for the fan of the oilcooler),2 oldshool VDO gauges (pressure, temperature) and my Ampco top cilinder oiler.
Dirty Harry said:Hi Alistair,
I build the engine with NOS German type3 heads and these are not suitable for leadfree gasoline.
The Ampco oiler lubricates the valve rings and the upper piston ring, the oil for it is http://www.marvelmysteryoil.com/" onclick="window.open(this.href);return false;.
You can simply add this oil to the gasoline as well but that would be a lot of calculating, once the system is set up you can do about 6000 km before filling up the bottle.
These oilers became popular in the US at the time the lead got out of the gasoline.
