lucifar666
This has happened before, I thought I had cured it with a new solenoid but it has decided to return.
The ignition is turned and the starter turns the engine over, it doesnt fire up and the starter keeps turning the engine over even with the ignition off and the ignition key out , The only way to stop it is to pull the battery lead off, or it just turns over till the batterys dead and the earth is smoking red hot. Then try it again a few minutes later and its OK and fires up!
Any ideas or do I need an exorcist
