Peed off. Out in van with new SSP engine, new clutch and release bearing running her in gently and now if I depress the clutch in it sounds like something Is rubbing.
Get definite whirr, rubbing sound, increases when clutch pedal is fully down. Sounds similar to release bearing noise on that t2 sound troubleshooting guide
I'm going to have to drop the engine again, that's twice in two months - guess it should be quicker this time :-(
Gearbox is old type without tube and I believe the clutch is correct 111198141X from heritage.
I think I adjusted the clutch correctly maybe around 1/2" before pressure change, maybe a bit tight...have I cooked the bearings but not setting enough play? Worried that if I change it the same will happen.
Anyone have any clues?
Some thoughts are:
Not enough play set in clutch
Too much play in Release fork bearing, will check when out
Bent forks so bearing not pushed no square
Not a good week see other posts...
Some thoughts are:
