Ands1
Last year I fitted a new Heavy duty fork kit, clutch & release bearing to my bus, I also fitted a new clutch cable & set up correctly, all good quality parts from M7.
I did a run from Manchester to Cornwall & general messing about last year, so probably about 1200 miles tops with new parts.
Just recently after getting bus out of storage I've noticed when warmed up it's difficult to find 1st & 2nd plus a crunch when getting reverse, So I adjust
the clutch tighter as instructed in Haynes manual, now I get a smal tinkle noise from engine end that goes away when I marginally or fully press the clutch pedal, in theory this is telling
me my release bearing is touching the clutch release plate mechanism which is a bad thing as it wears out the bearing quickly SO I loosen away the fork / bearing on the cable
by a small 1/4 turn on the nut / cable but then I struggle with 1st & 2nd again & reverse crunches.
Anyone had this before?
Seems ok when cold but when warmed up the gears get difficult?? I'm confused.
Thanks for help Andy
