Baldrick
Hi all
Just typical :roll:! The first weekend when I've needed to use the leisure battery and I have a problem
I have a Ring RCT360 split charge relay and it has managed to melt the cap on the end of the in line fuse. It isn't situated near anything hot so it hasn't had any external heat applied to it.
Got any ideas what it could be? Is it likely to have damaged anything else? The fuse is still intact, although I don't know what rating it is.
EDIT:
Sorry should have said that the wire with the inline fuse comes off the live terminal of the main battery and goes into the relay.
I could cut the wire and put another inline fuse in...but I'm worried that there is something wrong here.
Andy
EDIT:
Andy
