hi i have a braking issue i am hoping u can solve then i can source correct part needed
i have a 1972 early bay i have changed the front calipers as old ones where seized fitted calipers and bled brake system but when i press brake pedal the left hand side comes on ok but takes a few presses to get right side to engage and when it does engage the right side stays stuck on and does not return but left hand side does return as normal they are new calipers i have to release bleed screw a touch then tighten back up to release caliper just dont know if it could be brake master cylinder or could it be brake compensator thanks in advance
