Hi all
Just collected an imported 69 delux so should be delighted, but a few niggles can you help
how hot should it be, its got a brand new engine in but after less than a mile the rear valance is boiling almost to hot to touch,exhaust is also red hot,it has an external oil cooler with fan if that makes any difference. I've had early bays before but did'nt remember them running this hot im now afraid to use it in case i torch it, could it be that because of the new engine its a bit tight, also which fuel would you recommend engine was built in the states, any suggestions more than welcome
cheers
cheers
