hi thanks, the problem i have is the engine is a 1971/72 but v w only put hydrolic cams in 1978 so y does this have them? one of the cams came out as u said with a magnet and is a hydrolic one?alwyn said:hi i need some advice on how 2 replace my cam followers can u replace them with out taken the engine out. the camper is a type 2 with a 1.7 type 4 engine just replaced all the valves but now now y its not running right . many thanks
hi engine no is cb...1700 1971/72 original. yes all the cams need replcing thanks 4 all your help much appreciated.alwyn said:hi thanks, the problem i have is the engine is a 1971/72 but v w only put hydrolic cams in 1978 so y does this have them? one of the cams came out as u said with a magnet and is a hydrolic one?alwyn said:hi i need some advice on how 2 replace my cam followers can u replace them with out taken the engine out. the camper is a type 2 with a 1.7 type 4 engine just replaced all the valves but now now y its not running right . many thanks
