Bookwus said:
......Lee has a bunch of good suggestions that will definitely improve horsepower but they are neither easy or cheap.
Really the only avenue open to you that is easy and cheap is to make sure that your current stock donk is well tuned.
unfortunately a stock engine is considerably detuned. the best you could do is make sure the points are spot on, valve clearences are correct and carb is set up correctly. all these are necessary to run properly really and don't tune or improve anything. so at best a well set up aircooled angine is sluggish and underpowered. thats why they are so reliable, and we all love them. they are not really workign at all, happy toi chirp along all day. when we tune, we don't really tune, just release the natural capabilities.
i have to say my suggestions are as cheap as you can get really. firstly you have to loose the single port manifold, though if you get twin carb setup on single port inlet, it should be improved torque, greater inlet velocity for same swept volume. but back to the point;
pair of secondhand twinport heads will open everything up and give a much larger scope of carburettion. whats a pair of used heads nowerdays? few tens of pounds? spend an afternoon decoking and seating the valves.
a set of piston rings? 20 quid? deglaze the barrels, fit the new rings and it'll spring life into potentially tired pots and get back as much of that precious compression if it's flailling abit?
granted used twin carbs aren't that cheap. can set you back a couple of hundred. but for absolute tight budget if you track down some t3 twin carbs + manifolds and all linkage parts. they'll bolt straight up and the linkages can be modded to fit to your t2 cable in a few hours, simples. i'd like to think you can get these for considerably less? as long as the spindles aren't like sausages in a corridor, they'll be fine.
i'd even go with a stock exhaust. no experience, but a t1 silencer is supposed to be very good on a t2, backpressure, flow etc. the rest i can vouch for extensively. before i had real money to spend on engines, budget refurbs went a long long way.
