Hi guys,
Been a while since my last update. Went down to see Karl and the camper on the 27th December. Things are beginning to take shape now. Karl has now replaced the front beam back in the vehicle along with all new ball joints, trackrod ends, etc...
After bare metaling the beam and treating any rust areas with chemical rust remover, it was then sprayed in two pack black along with all the suspension arms. The photos that follow do not do justice to the finish Karl has acheived on these items. He has also trial fitted the new Spax fully adjustable gas shocks on the front. Because we have lowered the front of the vehicle it is now possible to fit shock absorbers from a beetle.
On trial fitting the new wheels which are Fusch replicas, Karl noticed that the wheel stud lengths were just about adequate. So after a short discussion we decided this wasn't acceptable. The last thing we wanted would be to finish the bus off only to have a wheel come loose and possible come off. So the hubs were removed once again, all the exsisting wheel studs were then pushed out and new longer ones fitted.
Whilst I was there I removed the rear hubs, throughly cleaned the rubbish off with a wire brush, then Karl gave them two coats of rust treatment before priming and finishing in black gloss. We also decided that the lowering spring plates would benefit from a coat of black paint as well. So my job was to key the surface up before painting. Karl noticed that there was welding splatter marks which as Karl pointed out, if were not removed, when the rubber cushion goes around this area, it would tear it. It only took me 10 minutes to knock these off with a sharp coal chisel and hammer, but Karl being Karl, he doesn't miss anything.
Karl has told me the bus can be delivered to Lee the trimmer on the weekend of the 5th February which will be 4 weeks from this weekend. So the next time I visit Devon, it will be to help deliver the camper.
Karl tells me it will be fully painted and laquered when we deliver it. Lee should have it approximately 4 weeks to work his magic and then it will come back to Karl where he will then polish the laquer work. The reason he's doing this after it comes back from Lee is because it will give it four weeks to harden.
I just can't wait to see it in paint as it has been a long time coming but having said that, we've done lots of changes to the bus which are little features on the outside and little extras on the inside. All this adds up to time on designing as well as carrying them out but I can now see the end of the tunnel and the results of all the work gone into this bus, is going to be stunning!
Karl has worked really hard this week. He has had to renew two oil seals on the gearbox. They are the ones that are behind where the driveshafts bolt on. Word of warning, if you have to do this job, don't just take off the plastic covers, unscrew the seal housings and reassemble because certain dimensions have to be taken before you can carry this out and it is absolutely crucial. If these dimensions are not taken prior to stripping then you are undoubtedly going to have trouble with your gearbox. Karl has now replaced the gearbox back into the vehicle after cleaning and painting black. Also rebuilt the driveshafts with all new cv joints and fitted the spring plates and rear shocks.
I have instructed Karl to weld the bumper irons to the back of the bumpers and weld up the holes where the bolts would have gone through the bumpers. This will give a much cleaner finish to the bumpers once painted and refitted. On inspection of the rear bumper, Karl informed me that it would cost too much money to make the exsisting bumper look correct, so a pattern bumper was purchased. On receiving this bumper Karl was surprised at how good the quality was for a pattern part but unfortunately nobody makes the early rear bumper for the bay. The only replacement pattern one available is for a split. Karl will now look at modifying the ends of the new bumper to replicate the correct ends. If this is going to prove to be too labour intensive he will the remove the ends from the original bumper and transfer these to the new pattern bumper therefore when finished it will look identical to the original.
Haven't heard anymore from Volksworld. Hope the bus is still going to be in the show. If Karl doesn't hear anything soon he'll be contacting them again.
Here's a few pictures from my last visit:
Here's Karl brushing on the first coat of the rust treatment on the rear hubs that I'd previously cleaned up.
After this has been on for x amount of time, Karl washes it off with boiling water to neutralise it before priming and painting.
Here's some pictures of the front beam and suspension joints after it was all replaced back into the bus. All the original bolts which are being reused will be fetched in with the black paint. The inside of the beam cheeks will be fully waxoiled so no more rot problems will occur:
This is the rear spring plate after I'd removed the weld splatter and keyed it up for paint.
Here's the plate, ready for etch priming.
This is the hub you have to unscrew and remove to replace the oil seals. To do this, Karl had to make a special tool fit in the middle so it could be unscrewed. You have to take a dimension from the face of the hub to the face of the gearbox case. This is critical! If this isn't carried out it can put all your differential out of line and wreck your box. After Karl took this dimension, he then put a centre mark on the lip of the case and edge of the hub so they lined up and also made a record of how many times he unscrewed it. The actual job is simple. All these is to renew is the oil seal which Karl said the reproduction ones are much better than the original design and there is an O-ring which fits around the hub which should also be renewed. Once all this has been throughly cleaned and removed, it's just a case of screwing it back together. Check the number of turns you go in and line the dots up and it's job done.
Here's the gearbox after they were renewed. All that needs to be done then is to refit the two plastic outer covers. Hope this information could be helpful for someone. You'll know whether the seals need replacing because you'll get a weep down the side of the gearbox.
This was a picture of the tortion bar after removing the spring plate. The first time off in forty years, still as good as new!
Here's another picture of the front beam. Karl said when I first drive this bus, after steering round corners I'm going to have to physically pull the bus back straight because the steering is going to be so tight. It will take approximately a thousand miles to loosen up. Again it's ashame the photos don't show how good the paintjob is. It really looks the business.
I also asked Karl to renew the bushes for the gear selector rod which slides through the tunnel through the middle of the bus underneath. To do these you need to remove the gearbox. I supplied Karl with some new bushes which I bought, they're like miniture plastic shuttle cocks. After Karl had inspected them, he said the quality was poor and they didn't fit anyway. The exsisting ones were found to be perfectly ok so everything was cleaned, greased and painted and replaced back in the vehicle.
This is the stage we're at at the moment. So if everything goes to plan the next post you'll see it in paint!
Regards.
Steve. Any comments much appreciated.
P.S. Happy new year.
