This is a question that keeps popping up on various forums so when I changed mine I did a bit of a write up to make it easier to explain:
My scrapers had pretty much disappeared so I replaced all the rubber seals.
Started off by removing the interior door panel to access all the screws/bolts etc for the door. The plastic lining also disintergrated as I took it off so will need replacing too.
I took the exterior handle off first which is held on by 2x 4mm hex bolts.
Then I removed the grey metal channel which the end of the long felt channel sits in. This is held by a 10mm bolt at the bottom and a slidy clp thing at the top. It just pulls out once you've removed the bolt.
Next I took off the door release handle, again secured by 10mm bolts. and the long rod that leads to the release mechanism thing. You need to undo the clip which holds it into place and I find a small screwdriver does the trick nicely.
Then onto the release mechanism thingy, held in with 3 cross head screws. Should comemout easily once released and drop down. These are usually pretty crusty and gunked up so it's worth cleaning up before you put it back in.
