67westy said:
Sounds like a good price. guess I need to finish my research now, maybe someone here can answer a question for me. We're currently down 2 splines at the rear so with these plates can we undo that and keep the same height or is that asking too much of them?
I believe so as they are already 'raised' 25mm so thats an inch lower already, someone will confirm but you can mix and match so a 1spline drop [nearer to std geometry] and the kick will be close already to 2 splines.
Sure someone like Ash [dubscum] can confirm or even Ted from Slamwerks, it would be very useful to see a table of approx drop according to settings
ie no spline drop = x-y inches [using the adjustment available]
1 spline = x-y inches [again using the adjustment available]
I have other stuff to spend my cash on really but I have wanted these for so long I'll say I'm in....
1. 5erge (London/Bristol)
2. 67Westy
3. R73
4. The_Troupster (+ dropped spindles)
5. Baj
6. Mr Brightside (Chesterfield)
7. Rob b Leicestershire
8. Antione - Maybe
9. Robby - Maybe
10. dubdubz - Peterborough
11. marcher - kent
12. Pete B - Peterborough
should we adjust the list so the definites are up top so we can check the numbers...as I think we have the numbers but some are not address confirmed......
