R redstar5 Well-known member Joined Nov 17, 2008 Messages 45 Reaction score 0 Feb 13, 2009 #1 My van has been away for some restoration and I noticed that my indicators looked a bit funny. Are they on the wrong sides or is it just me.
D dave Well-known member Joined Jan 11, 2009 Messages 413 Reaction score 0 Location near Woodbridge Suffolk Feb 13, 2009 #2 Yep, just checked mine and they are the other way round, do you need to swap units from side to side, or can you rotate them by 180 degrees???
R redstar5 Well-known member Joined Nov 17, 2008 Messages 45 Reaction score 0 Feb 13, 2009 #3 Cheers I thought so. The units will need swapping as the bolts are slightly different distances from the edges so they wont rotate. Cheers. :roll:
Loxy Well-known member Joined Nov 18, 2006 Messages 2,855 Reaction score 0 Location Abergavenny, South Wales Feb 13, 2009 #4 redstar5 said: Cheers I thought so. The units will need swapping as the bolts are slightly different distances from the edges so they wont rotate. Cheers. :roll: Click to expand... Check the manufacturers mark on them is the right way up. You can rotate them - they just end up slightly further in/out (I had one the wrong way round on mine when I got it).
P ProfessorWheeto Well-known member Joined Mar 12, 2007 Messages 1,638 Reaction score 0 Location Lincoln Feb 14, 2009 #5 Remember to check both the lenses and the metal backs as they are both stamped L and R Have seen more than a few sets that are all mixed up and back to front!
