inlet
super-craig
Mar 6, 2008
243
derby
Hi been checking over the 68 and found a small pin hole in the heat riser tube to the inlet manifold , can these be bought seperate or is it a complete manifold i need to buy
You've gotta buy complete manifold,i've got some if you need one.But if it's just a pin hole weld it up.
Steve
one tube got just a pin hole in it , was going to repair it , but thought if you could replace them i would replace the holed one
There are some aftermarket ones available where the heater tubes do come away however I suspect this isnt the case as they are obvious to look at....
the inlet manifold is alloy with the 2 risers in steel , so they could come out i suppose with a bit of persuasion :lol:
could weld them , but if you can replace them easy enough , was going to do that , guess its welder out time 8)
