Interior Build - 1970 Import - Made it in a magazine
Webbaldo
Mar 11, 2014
756
Well after breaking my other thread and losing the plot with photobucket, thought id just do an interior thread instead.
In short after 2 yrs my van is ready mechanically. Was never meant to be (AND STILL ISN'T) a total resto, just rust free, mechanically sound and all one colour. Dints etc all stayed as I like them :)
From this in March 2015
To this in late 2016. Took a while as have a little'un now. Basically body was done on the drive, spent most money on running gear. Except the timing, done everything myself. Sprayed it in rustoleum so looks crap close up but its all Neptune blue so I'm happy.
This will cover the next couple of months making a sundial-inspired interior on the cheap.
Heres a 3-day update
OK so after de-mechanising the shed, ive turned it back into a woodworking shed for the van interior
I plan on making a Wardrobe for behind the drivers seat, buddy seat, folding table, and fridge unit. Hopefully by the end of april.
Obtained some old shelving from work, I'm building the cabinet exteriors out of Birch ply but its expensive so for the insides/frames they will be made of anything I can find
Ripped one down already for 1x1 framing for the wardrobe
So wood arrived for the wardrobe/buddy seat and fridge unit yesterday yey!
Wardrobe is going to be made from 6.5mm ply, other stuff 12mm. To keep weight down.
To save material, money I found a good little bit of software. You type in the wood size, and cuts needed and it plots it all for you.
Need to cut it tonight before the sheets start to bow
Basing the build on eriba style method. Thin wood and framing.
So all wardrobe parts cut out
First wardrobe side glued up!
For reference, I'm loosely basing my interior on a Sundial layout I like. Kinda nice parts of a westy but with full bed and front wardrobe. Quite a rare layout but I like it. Plus it works for us three. After having a t25 with a 3/4 bed, never again. I'm too tall and fat for one.
Looking at the brochure I'm not sure about the cabana attachment or not!?
Bit done over the weekend
Frame done using glue and pocket holes
Got the door sorted
So that's the wardrobe carcass done. Needs varnish, handle.
Corners aren't perfect but don't need to be as I'm cladding all the corners in Alu trim.
Couple days off DIY then will start on the fridge unit.
Van wise, went out on its first bypass run. Went fine at first but struggled a bit on the last bit home. Got home and all 4 corners were warm. I realised I hadn't adjusted the servo rod when I fitted it, so the brakes had a little preload to start which obviously got worst when running. All fixed now but have to bleed the brakes again :roll:
subheatadey said:
Looking good, out of interest what pocket hole Jig do you use?
Just the Kreg mini jig, about £10 on ebay
The big ones with the clamp are good but for what I use this is fine. I just clamp it to a table when drilling the holes.
Made a right-angle jig from wood as well when screwing the bits together just to keep them at 90degrees and level
Well with the wardrobe just awaiting cladding/varnish thought id better start on the Fridge unit
Just done a quick mock up to make sure they fit
Will do the back frame tonight then glue/nail it together. Need to make some 6mm plyshelves for the bottom and middle.
Great project. Not only tackled the metalwork and produced a damn fine job, but now adopting new skills again and getting some nice finishing here. Like that your basing the design on old skool original furniture. Watching with interest.
thanks for the kind words.
I enjoy the woodwork. Built my teardrop from scratch a couple year back. Sold now :(
That's a very impressive transformation in a very short time, nice work fella.
Well varnished everything this weekend. Turned out ok never have any luck with wood finishes.
Clad the buddy seat with trim so that's finished
Awaiting more trim to clad the wardrobe and fridge
Fridge unit finished hoorar
Fridge is 240v but can be used and an oldskool ice box when off hookup via big ice block
Absolutely loving this. Much respect!
By the way: I want a trailer such as the one you built.
Stefan
Stefan
Cheers for the kind words!
I actually still sell the template/plans on ebay *cough*ahem*salesplug* lol. Just search teardrop trailer and look for mine.
Need to clad the wardrobe in Ali next.
Couple of people have asked about the tops. Their old school desk tops from where I work which were being chucked out. After realising how much formica costs I nabbed them quick!
The white edging is Arcade machine T molding.
