rob83
Active member
Hi guys,
Trying to get the wiring sorted on our US spec 68x deluxe. I am nearly there. Looking at the wiring diagrams on the samba, my van matches the wiring diagram for a 68 however the hazard light swich and relay appear as in the post 69 wiring diagram. Ie it has a 4 pin relay and associated switch rather than the early 9 pin and 2 pin switch. The van looks like it was made in mid to late 68 so could this have been like it from the factory or is it more likely to have been converted over the years?
I only ask because the relay seems a bit intermittant and when you indicate left the dash telltales flash, as they should but when you indicate right they flash once and that's it... Very odd. Thanks for your help guys!
