Mike F
I've taken advantage of the superb day to get out on the van - wash and wax as suggested by slammedkustom after my cover problems.
Having got round half the van I took a break to investigate a water seepage problem. The area between the spare wheel well and the rear door had been damp for a week. I've put teatowels down to dry it, put square pots in to check for the leak and generally presumed I'd need to look at the seals.
I have now found that the spare wheel well was full of water, then overflowing which is when I noticed it.
I've drained it and left the wheel out to investigate day by day.
I see there is a drain plug at the bottom, filled with a rubber grommet. I guess I could remove this but water would then soak the leisure battery.
Any thoughts?
Any thoughts?
