I have a battery 12v 110ah. Will this be good enough for a leisure battery? Is it to powerful or not powerful enough? Cheers
Happystamps said:110Ah is a good sized leisure battery- used to be the biggest 12v leisure battery you could reasonably get your hands on, possibly still is.
Make sure it's a leisure battery though. You're probably fine considering the size (common LB size), but if it's a regular (big) starter battery, you run the risk of warping the plates if you're constantly running it flat.
