Lets see your todo list before the show season and summer.
AxlFoley
Jul 19, 2008
2,754
16
cardiff
Just started to write a to do list of all the things i need to sort out, preferably before teh VolksWorld show.
mine goes like this;
Clean interior.
Treat all surface rust on cargo floor, and paint with Por 15
Replace the lyno
Sound proof and insulate the entire inside
Replace the headlining, and wall panels inside
Fit new handbrake cables
Tidy up dash wiring
Fit Rev counter
Finish recovering my interior
Re fit my westy interior.
looks like I'm going to be busy!!
Sort out misfiring
Repair off-side middle window aperture
Repair off-side rear window aperture
Cut off-side and rear gutters off and replace with cuts.
Cut rear roof and hatch opening off and replace with cuts
Replace rear corners
Repair near-side rear inner wheel arch
Replace rear arches
Repair cab doors and fit opening quarterlights, rubbers, scrapers, etc
Repair sliding door and fit seal
Repair engine lid and fit seal
Repair rear hatch and fit seal
Replace balljoints
Weld and paint bumpers
Fit insulation, headlining and interior
Make cooker/seat unit for behind driver's seat
I think there might be a couple of other things, but they've slipped my mind at the moment.
Oh, yes, get some work to pay for all the above.....
:lol:
Right then this is the first list:-
Fit new master cylinder
check through brakes
Fit new hand brake cables
bleed brakes
fit new bumper iron
clean load bay floor
repaint load floor
Repaint cab floor
Replace fuel lines
wire rear brake lights
Fit new battery
refit bumpers
fit bumbers
Fit new seat belts
MOT -hopefully
Register
Make new ply side panel
fit 240v
fit 12v
refit interior
fit new curtains
fit new indicator switch
That's all I can think of at the moment, but I'm sure there is more :? :?
MOT
Take to paint shop (fix dent that happened on ferry)
Rebuild Porsche engine
Fit Porsche engine
Finish trailer
The sad thing is it's the same list as 6 months ago!
Fit N/S sills inner and outer
Fit O/S sills inner and outer
Make cargo floors
Fit cargo floors
Fit cab floors
Repair rear bumper mounts
Repair engine bay tinwear
Fit rear valance mounts
Finish weld front clip
Repair front valance
Repair windscreen surround
Finish weld the load bed
Narrow a splitty beam
Strip the whole bus
Clean paint and protect the underside
Prep and paint the inside
Prep and paint the outside
Rebuild all the mechanical components
Rewire the bus
MOT
register the bus
get some plates made
2 weeks shake down before Deva!! 8) :lol: :lol: :lol:
paint engine tin
remove engine,fit p&Bs twinport heads .
heatexchangers,control cables.
paint engine bay,and any bits as nessecary
rev counter
cd player
tailgate water leak
towbar
paint rims/bumpers
check over dragrace beetle
by april :shock:
Sevice engine and re-install in bus
New panel to top of engine bay
New fire extinguisher to install
Re-thread valance bolt holes
Re-thread one bumper iron bolt hole
Install new master cylinder
Bleed brake system
Adjust rear brakes
Install new steering idler repair kit
New track rod ends
Fit new speedo cable
Fit new monster tach
Connect cylinder head temp gauge
Fix electric washer system
Polish wheels
New front tyres
Tracking
All for Ninove :shock:
Reassemble engine.
Degrease and clean engine bay
Refit engine
Fit rear adjustable springplates
Get new wheels
New front tyres
Recheck tracking
Bleed and set up brakes
Again, ready for Ninove and allowing some shake down time :?
Rustproof the chassis, por15 the underneath, sills where the og paint is flaking off, and front floors.
CV boots and and ball joint boots
Window seals and refurb westy windows
Get new battery tray fitted. (got parts)
Plumb in gas
Buy a towbar
Fit the propex (once I've fixted it)
Fit the new westy hinge repair kit
Fit a Zig unit
Fit the amp and fit speakers to kick panel
Fit the CB and get the 8 track running
Fit the tacho
Fit the new bumper overiders
Fit the new carb and manifold
Fit the mondo exhaust and new header
Redo floor with new westy like lino
Redo the interior with sound proofing and insulation.
Fit the new westy tap
Fit the spotlights
Fit the new steering wheel
Fit the side jailbars
Drain and re fill the gearbox oil
Check valvles and clearances, oil change
Fix the heating so the flaps are not wired open
Fit new bearing and bushes to the steering idler pin
Fit new shocks
Fit the stainless braided brake pipes, and renew all copper lines
And that's just off the top of my head, there is loads more to do, but to be honest, when the weather is cold, nothing gets done, and when the weather is good and sunny, we are out in it - hence quite a long list of jobs. And with a new baby in a matter of weeks, it's a list which is only gonna get bigger!
Cheers!
Alistair
Finish making my stainless exhaust system to quiet down the "quiet pack", so i can drive normally through towns without sounding like a boy racer.
The TO DO list is never ending and generally more a want list than a need list, (some of the bits i have the rest am collating/building up money for)
Adj rear spring plates
Steam clean of underneath
Re fit 2 side windows where i cocked it up on the first go,
re fit all windows with proper deluxe trim rubbers and inserts
Re-waxoil and undercoat
Interior (LOADS to Finish it off proper)
Split Charge System
Tracker
Stereo
Mini PC
Fire extinguisher system
Roof of Engine Bay panels and sound deading
Tow Bar
Propex
the what NEEDS to be done is actual pretty small,
take it for a quick tune up,
MOT
Then drive it, so many people don't get to enjoy their vans cos they are worried about the TO DO list, my opinion, but i think most of the TO DO Items can be done when it's on the road and being enjoyed, I spent the last 2 year driving around with a half finished van in various stages, the first year it was in primer patches looking well rough, AND I STILL ENJOYED myself, so what if it looked a bit shabby, just put off the bits that don't get done this winter till the next time it gets rested up ;)
I agree with that, its the wife that doesn't lol
My to do list,
Respray
Repair loose exhaust stud (driving round in a mini aushwitz :lol: )
Make / Build / buy an interior
replace vinyl head lining (probably will be on next years to do list aswell!)
Fit all the bits i bought last year
As of 4 weeks ago the bay is my daily so its getting used in all weathers (probably meaning the to do list will grow :shock: )
Also considering buying and re-conditioning another engine 8)
All above depends on whether we move or not :lol:
