rupert the bay
WTP sleepless 21"tt frame
Chester blacksmith signature frame, full magma heat treated sanko 4130 cro-moly with cast drop outs
pretty much as new, few marks here and there , round the drop outs etc..4.8lbs, seat clamp inluded - original paint & stickers
£100
WTP 2012 Volta 21"tt frame
Original black paint & stickers 2012 WTP volta, full 4130 sanko butted tubing with hydro formed downtube gusset, paint worn from chain on the lower chainstay, other than that, its in mint condition, 21" TT built in seatpost clamp
£90
WTP crysis 20.4TT frame
has been painted (wuite nicley) inmetalic blue - now has some chips and marks, but strucurally straight as a die- £40
WTP 2011 volta 21"tt frame
Full Sanko 4130 cro-moly frame with cast drop outs and 21" top tube (almost identical to the sleepless except for subtle diffences to the cast drop outs)
snot green original paint, several chips / marks ...could do with a good wash...or rub down and paint to cover up that vommit green paint - but rock solid frame with no dints or sturctural damage, just chain marks and the odd scratch
sweet frame, including seat post clamp - £75
WTP Volta hi-end forks in Snot green - full 4130 CrMo, CNC 1pc steerer, heat treated drop outs - complete with top nut - £25
WTP crysis forks - full 4130 cro-moly 1 piece steerer - complete with top nut- £20
WTP Volta hi-end forks in sat black - Saltplus Fork 4130 Sanko Tubing, CNC Steerer, inv. Cast Dropouts - complete with top nut - MINT - £50
Vocal Local XL bars in chrome with good black ODI grips - £35
WTP Full 4130 sanko bars from 2012 volta in black, with eclat Chester B signature grips and Saltplus CNC 50mm reach stem - £40
WTP Saltplus "Metron48" tubular 3pc crank cr-mo, 175mm, 48 spline cro-moly axle, with Eclat pedals, saltplus sealed bottom bracket & commencal 25t alloy sprocket...all you need, bolt on 48spline tubular crankset - £75
WTP Saltplus "Metron48" (L&R) tubular 3pc crank cr-mo, 175mm, 48 spline cro-moly axle - Mint - £45
WTP Salt AM 3 pc tubular cro-mo, 175, 8 spline axle, salt sealed BB & Salt Plus 6061 T6 Alloy, CNC, 25T sprocket - £30
36h Eclat "Trippin Aero Double Wall Front Rim, in Black with Saltplus Female sealed hub in White - black spokes - £35
36h Eclat "X-odus Straight Double Wall Rear Rim in black with Saltplus cassette 9t L&R switch drive sealed bearings - Black spokes - rim has brake fade - £55
36h Saltplus aero Hi-Q lite rim in black with salt am low flange sealed hub in black, black spokes - £25
36h Saltplus Straight Hi-Q rim in black with Salt AM Cassette, 9T 1-piece cassette driver, sealed bearing, black spokes (its missing x1 spoke) - £45
36h éclat double convex wall rim (aero) in blue, black spokes & black sealed female salt hub , with as new Primo dirt monster tyre/tube - £45
36h éclat double straight wall rim in blue, with brake fade, black spokes & black Salt sealed 9t cassette, with wethepeople tyre/tube - £60
36h 36h éclat X-odus Straight Double Wall Rear Rim in Chrome, black spokes black éclat selaed 9t cassette, with mint Primo V-Monster/tube - £70
Eclat WTP Volta Pivotal seat with alloy post - £15
£100
£90
