Lots of early bay stuff engine chassis lights etc
shroom
Jun 5, 2010
177
Lots of my last thread has been sold so here is some new added stuff up for grabs
Crew cab roof £200
Front chassis happy to cut up for couriering £130
Middle chassis happy to cut up for couriering £60
PM me about any body cuts you need
RHD gear stick with extension £25, £30 posted
Pair of Crew cab gate locks £25, £30 posted
Horn £5, £8 posted
Totem £20, £25 posted
Very straight front bumper £120, £135 posted
Front bumper irons £25, £30posted
or bumper irons and bumper £135 £150 posted
RHD windscreen wiper mech £45, ££52 posted
Rear crew cab door, welded on lower section but pretty good £45, £58 posted
Uncut metal RHD dash £65, £78 posted
Pair of Custom door pulls (3 shown) £6, £8 posted, winders £8, £11 posted
Petrol tank £55, £67 posted
Rear gear stick connector rod £25,
RHD Steering box NO idler arm £80, £87 posted
Shroud including non-standard barrel and key £20 Posted £25
68 bolt on (not grub screw) Windscreen wiper arms £12, £15 posted
Not so good rear valance £40 (£50 posted)
New 68 clutch cable £5 £7 posted
Engine compartment stay £8, £10 posted
Brake peddle and linkage £15 £19 posted
Clutch peddle and linkage £15 £19 posted
Left and right inner cill £30
Left and right outer cill for a crew cab £30
Pair of brand new hella front headlights £125, £135 posted
number plate light cracked platic but that is over where the metal is £17 £20 posted
westy fold down table £10, £15 posted
Plastic ventilation tubing, all pieces (the stuff that connects to vents etc) £20, £25 posted
1600 Twin port 10k miles, alternator, carb and stainless exhaust new at 10K Ready to bolt in £950.
RHD early bay wiring loom, needs attention to one part where has melted insulation where welded £45 £52 posted
Front brake spring retaining pin repair/rebuild kit £8 £10.50 posted
Crew cab rear window £40
Oilbath air filter £25 £34 posted
Pair or wing mirrors one no glass £10 £15 posted
Or pick up from East Dorset (Christchurch near Bournemouth).
E-mail at iaindhill at yahoo.com
Phone 07904577725
Iain
hi JS
the section where the rear diagonal downwards touches the floor is toast *(one of the reasons why van was scrapped) however have the diagonal downwards pannel is ok from 2 inches from floor if you could use the metal. Otherwsie you need to make something bespoke to fit as others have done on your thread hard work but that is the only solution that i can see sorry as no panels are avalible although try musclebus or indeed schofield do do one off's
SOrry
Shroom
Hi Shroom
Thanks for reply. I'll check it out again. As you say may be some
of the metal of the right corrugation ca be adapted.
JS
i can cut the whole corrugated section out, from wheel arch to wheel arch no probs.
Shroom
I'm after the rear upper shock mounts, if they are in good nick and you want to take the off the chassis rails. Cheers.
as postage for cills is £12 (length once packed 155cm) then £37 posted or £25 and you get your own courier
Happy to cut from chassis the shock mounting.. i cannot rmeber if bum stop is same place as upper shock mount. If so i have already sold the earside on The off side will be £25.. if you have a pic i can tell you if i have it as away at mo
Shroom
OK sounds good. Whereabout are you ? I travel about a bit with work so might be able to pick-up as it's quite a big piece.. Oh yes how much ?
JS
i live in christchurch which is 5 miles east of bournemouth and 18 miles west of southampton. I have no idea how much i suppose it depends on how much you want. CAn you put a photo up for the section?. If it is just the flat bit with the corregation then post would only be £10 and perhaps £25 fo the section. But if you want alittle more then it would cost a little more. Tell me if you think i am taking the piss!
Shroom
NOt my van but this picture (yellow circles) shows the rotten areas.
Not in any great hurry for this since I need to find time to remove engine, fuel tank etc.
which is tricky with my nagging Mrs. :roll:
TBH I think just a couple of cuts 6 " x 12" would do it, but I will measure again.
Thanks again
JS
no problem. i will cut from wheel arch to wheel arch from about one inch above floor (as toast below) and cut into two to reduced postage
Iain
