I'm going to mark this one done now- while I've still got to seal the cover/box join (I left my hylomar out in the rain about 6 months ago with the cap off and now It's like blue wax!) everything else is done.
Copied and pasted from my VZi thread:
Brief update- I put the steering box back together. Isn't that nice!
The seal on the steering box didn't want to go on (bit too big) and I must admit that I took a pretty primative approach to that. I put the seal on a socket,
held it with an extension bar and span it round on the bench grinder. I'm genuinely surprised that it works perfectly, and doesn't even need sealant on the outside (trying to use as little as possible). I put oil in it and held the box upside down for 20 minutes or so without it leaking, figured that'll be fine.
Anyway, I built it up. Here's a photo of fitting the wee needle bearings into the output shaft/peg combo:
After that it was just setting the torque on that peg (Just shy of 2ft/lb, hold the peg still with a screwdriver or pliers against the washer tabs), re-fitting the seal onto the output and bolting it back together. I ran out of Hylomar for the cover so will need to re-do that as it has a slight weep (to be expected, but I really wanted to see how the modifcation had gone so bolted it all up anyway)
Once we were all bolted up and oiled, I cleaned up the threads on the adjustment screw and gave them a light oil coating. Then I wound it in by hand, while at the same time moving the output shaft in and out. With the screw completely removed, it moves about 1/2". just wind it it until you can barely move the output shaft in and out. Then take the input shaft flange and rotate it back and forth over the central point of the steering box's travel until you can JUST feel it becoming slightly firmer and back it off again about 1/8 turn, maybe less. Run the input shaft again and make sure that it all feels uniform.
Now, to test it.
I put the steering box in a vice, clamped a piece of wood to the input flange 22cm long (same as the steering wheel radius, so essentially a dummy wheel rim) with a reference surface and set up a Dial test indicator on the output shaft (I put the arm back on for this) so I could see when it started moving.
I'm happy to report that there is around 0.5mm of play at the wheel rim before the output shaft rotates. Bear in mind the MOT requirement is 70mm or less. DTI moved smoothly and there was no graunchiness at all. In fact it was like butter.
So there you go, I think I've fixed my steering box. Happy as Larry.
