here is a few updated pics for everyone I know how you all like pics and I like see all yours so only fair. I have now invested in a sandblaster and started using recyled glass to blast all the areas with surface rust unfortatunatly its found some more areas for attension.
here is a new section of sill welded in after removing the old rusty one full of holes due to bodged US repair.
Hate the westy eletric point and its no use anymore. When i started to remove the paint to weld up where it used to be I found loads of filler, at some point someone has cought the plug and bent all the panel and then banged loads of filler in so once it was all removed I could see how bad the metal was around so there was nothing for it so I cut it all out and let a new peice in.
New peice let in, I did it very slowly keeping it cool and the end result is very straight panel only needing a light skim of filler.
Fully welded and ground back.
Under the window cut out to a point easy to grind the weld back.
New peice in, new panel from Just kampers wasnt very good match for the profile so had to give it a good tweek.
Here is a few areas I now have to replace after finding metal was rubish with the blaster.
Not sure how to go about repairing the headlamp bowls. weather to cut round the bowl or just replace to afected lower half?
