creationblue
Tofufi said:Millhouse said:I've done a compression test, all four cylinders are 90. Is that good?
90PSI per cylinder would be what I'd expect from a very worn engine. Were you doing the tests with the throttle wide open?
I'd be hoping for 140-150PSI per cylinder on a freshly built engine...
Most people don't realise this, but its the difference between the readings you have posted and (hopefully) your actual readings.....fingers crossed for you
