Xfilesrool
Active member
- Joined
- Jun 30, 2018
- Messages
- 33
- Reaction score
- 0
gvee said:Carbs are funny beasts that I still don't fully understand (despite rebuilding a few in the past). Because of this I'd focus on the other things that can contribute to the problem you have described, first.
Start with checking the exhaust system (including heat exchangers) for leaks.
Then I'd check the timing.
ozziedog said:Hang on a minute before you start throwing money at it and muddying the waters. Check your fuel pump output using an empty water bottle and that’s free, when was your last points and condenser? What sort of ignition do you have ? What are you setting your valve clearances at? Have you changed any plugs recently? Have you tried changing your plugs one at a time ? Have you tried taking the plug leads off one at a time to see if it alters or stays the same.
Ozziedog,,,,, freebies first of course :mrgreen:
