Oil filler drain tube
Howie123
Sep 8, 2011
237
Cambridgeshire
I'm missing the drain tube that comes from under the oil filler (the one that goes down through the tinware) :roll:
Looking at parts it seems these come with the pipe already attached to the filler or is there a way of attaching a new pipe or another solution ?
This is not just a drain tube. It has a one way rubber valve at the end that is VITAL for proper engine breathing. Without the tube and valve, the engine will not run as VW designed it - with slight negative case pressure.
The tube is swaged on to the filler top so there isn't an easy way to replace it. I suggest you get a decent s/h filler top and tube, unscrew the collar inside the filler to remove the old one (heat the collar forst with a hot air gun to soften the baked oil deposits) and fit the new one. Then make sure you fit a proper valve to the end - many of the repro valves have the end sealed so be sure to cut a slit in it with a blade before fitting it.
https://www.vwheritage.com/shop/113115451D/oil-fill-funnel-dynamo-no-cap/" onclick="window.open(this.href);return false;
£11.95
https://www.vwheritage.com/shop/113115495/union-nut-oil-filler-top-t1-61-79-t2-60-79-r/" onclick="window.open(this.href);return false;
£8.56
https://www.vwheritage.com/shop/253260180/rubber-valve-oil-pipe/" onclick="window.open(this.href);return false;
£2.75
and the tool:
https://www.vwheritage.com/shop/AC000139/tool-oil-filler-nut/" onclick="window.open(this.href);return false;
£8.75
All above prices are retail you will get your EB discount on top (except any items already in our sale)
Hope that helps
Looking closer at your pic i think yours is chrome so you may want:
https://www.vwheritage.com/shop/AC115311/oil-filler-w-tube-chrome/" onclick="window.open(this.href);return false;
£17.20
