:? no,had a look and could of come from the pipe with the rubber thing on the end :roll:sparkywig said:Are you sure it's oil, and not dirty condensation from the exhaust?
aogrady said:Hi Rich,
That rubber thing on the end of the tube, isnt that just a breather pipe running from the filler tube?, maybe excess crank pressure and it's blowing more than it should? though didn't your engine get rebuilt with rings etc?
Were you not running twin carbs? you can rebuild the spindle on the stock pict solex, yours is the original SP? 31 PICT Solex?
Aside from that, sounds like rocker covers or pushrod tube seals....my bus leaves quite a few spots on the floor, seems to be higher up on mine, though the back o the bus is clean from oil, i do need to sort it.
Cheers,
Alistair
robins said:aogrady said:Hi Rich,
Cheers,
Alistair
ok mate how isit
