Right haveing a few issues with the engine ! , Have checked and re checked all the gaps, tolerances ect involved with the engine as per spec , all plugs are sparking as they should and all ht leads are in good condition, im running a svda dizzy points are set correctly and the timeing is as it should be idleing at BTDC 7-8 degrees , advanceing without vac line connected to about 28-30 and with line connected to just abouve 40 degrees ,
The problem i have is there is a real lack of power on the lower rev range can just about get up to speed but its like your dragging a dead weight behind you like a serious flat spot but not like you would get on a 009 dizzy , and it also seems to be running a lot hotter than normal as in very hot dip stick and the oil light will flicker on tickover when its hot , the engine was totally rebuilt last year and ran more or less fine although was running twins then . im now running a 34pict 3 solex which i rebuilt the other month , this was the original carb i used to run but took it off as it was getting tired and leaky . And dont ask why i have swapped back to a stock carb lol , needs must and all that
Noticed today while swearing at it again that when you hold the throttle about a 1/4 out it will pick up revs but then struggle to maintain where it is and trys to stall but dosnt quite , to get past this you have to open it up to about half throttle and will stay at that fine , the same with full revs , will rev up fine from idle to max revs if you just suddenly open it up full , but when on the rd and you do this it just hits a serious dead spot and struggles to pick up speed bit like you have left the handbrake on ( and no i havent lol ) like i said used to have a similar proplem with this carb years ago along with it leaking fuel from the spindle , which is the reason i rebuilt it , the only difference is i put a new slightly bigger main jet in . it also sometimes takes a while for the revs to drop back to idle after revving
so after that essay above if your still awake anyone got any ideas ????? if you plz as got mot booked in a week and although can get it there just about as dont like this hot running and camper jam is looming :roll:
