28.10.2017
Yesterday I started to weld the patch in. A few tacks then started to seam weld - once the wind dies down will try and finish!
Moved things around in the garage and decided to split the pressure regulator that reduces the brake pressure to the rear drums.
Decided to split it and check how it looks - not to bad inside, a little gunge which I removed then tidied up:
Put it back together then wire brushed it:
Still needs one of the stuck bolts removing that connect it to the chassis - will ask a local garage if they could have a go.
So, to stop it rusting again, tickled it with some paint:
Plonked all the now painted and refurbed bits into some plastic containers until ready to put together:
Arms just on a shelf for the mo:
Also had put some more bolts, nuts and washers in acid yesterday - pulled them all out and some of the washers had broken in two so won't be using them!!
If weather is OK tomorrow will spend time finishing adding metal etc to the cab floor.
