Rear disc brakes (economy version)
Tried to open the DXF file today but is is only part complete (about 34K)
is there another file to go with this one or is part missing?
Paul
if open the dxf file it looks like two different sides of two separate plates? thats what i cant understand? two laser cut plates bolted together or one piece machined?
does anyone know how close porsche rear rotors would be to bus ones fit wise bigger or smaller?? would it take much machining? you know an EB drum machined down and the rotor fixed to it as in one of those other threads>
the 2 pieces bolt together but the tapped holes are missing from the drawing
you can see on the photo on the first page where the bolt heads have been ground off
apparently the files were generated in Finland where it's illegal to weld caliper brackets hence the bolts, however I guess you could weld them togeter for the U.K!
