Set of 4 Jaguar alloy wheels. 16x8J. Made in Britain.
PCD is 5 x 120.65, (I think – same as Chevy pattern so you can buy the aftermarket drums and discs off the shelf to fit these wheels)
In good condition although there is some lacquer peeling off the alloy finish. That’s what you can see around the rim, not damage – just lacquer coming off.
That shouldn’t be a problem as I’d say these wheels would look the business polished up, and being quite flat, polishing will be cheap enough too.
The Gunmetal grey painted areas are in excellent condition and wouldn’t need painting again at all. Perfect as is. So just the polish up the alloy finish and imagine what could be…
£140 the set!
Cheers,
Jonesy
£140 the set!
Cheers,
Jonesy
