RHD Westy - Back home at last
So here's the dilemma, you are lucky enough to own as near as damm it a stock bus but you know you want to take it away on longer trips, you promise yourself you won't make any modifications and plan a trip to France with all newly serviced. It breaks down and you end up having it returned home on the back of a trailer.
Didn't put me off the idea of travelling to Europe, but did make me think about what to do engine wise. I had already decided that it wasn't going to go into any more Show & Shines as we were lucky enough to pick up best T2 camper at Camperjam earlier in the year and that was always going to be a one off.
Considered three options when we came back, whatever happened the heads needed replacing, so that would have been probably the simplest and most cost effective way if I thought I could have done that myself, but space and my own small mechanical capabilities ruled that out. The bottom half of the engine was pretty good and had only covered about 10k as it had already been replaced by the previous owner in South Africa so it was a risk but probably a good one to take. Problem was the workshop costs to do the head work were likely to be more than labour costs for replacing the engine. So the decision was made to replace the engine.
The next question was which one? They seem to be so many debates about Vege or Remtec, most people agree that the out of the crate mexican engines were good but that source has long dried up and there is equal debate that the brazillian out of the crate are not so good.
Knowing that the bus was going to be a 'keeper' (I know, famous last words :lol: ) decided I wanted the security of a good engine warranty so went to the people offering a 3 year warranty for my own peace of mind to have a 1641 built from 'new' parts with the idea of having twin weber 34's fitted to give me the better economy.
So to cut a very long story short, bearing in mind the westy broke down in the middle of September I finally picked it up frrom the workshop with the new engine fitted this week.
In the end the spec included the 123 Ignition system because I'd read such good things about it not just from the VW forums, full flow oil system with oil filter not external oil cooler, having gone that far, in came new coil, new leads from a specalist company in Cornwall, new starter motor - because we thought there was a problem with the old one (but in the end that wasn't probably the cause of a poor starting problem) and oil temperature and pressure gauges to keep a close eye on the new build
So what's the purpose of the tale?
Well at the moment with the benefit of hindsight I think I would have just taken the more simpler route of replacing the heads, the frustration of this rebuild has been something else. Suppliers that say they have things in stock, take your money and then don't deliver for 4 weeks - each week saying its on the way!! Engine builders that have great customer service at the front end with a great willingness to put things right when they go wrong - why can't it just be right first time to save so much grief all round. Suppliers that still sell complete carb kits without mentioning that you will probably need to change all the jets to get the best results.
Once it's run in carefully I'll re-post with an update of whether this long drawn out process was worth it, at the moment its running, but I think a trip to Interpro once the running in period is complete will make a big difference. For the long term I hope the decision was right, but I have a feeling I might at some stage be asking Scott Wilson to keep his eye out out for a stock engine from one of his imports if a customer is having a new engine fitted and doesn't want the old lump.
But hey, the bus is back it's safely tucked up in the garage, plenty of trips have been planned for next year and for me the whole purpose of owning the westy hasn't changed - it's to be used and have fun and hopefully those smily days are just around the corner :D
Glad you've got the van back up and running, what engine did you decide on in the end?
I'm having the same thoughs as i know the heads on my engine will need replacing soon but with the price of a rebuilt engine from TES only £200 more then a pair of heads not to sure what to do.
You have PM
Garages, love them or hate them, we all have to use them at some stage in our lives :cry:
Mine has been in a garage now for nearly 2 years with the promise that it will be road ready any time soon :oops:
Given them a deadline of next April - will see :?
Hi David,
Glad you finally got her back. The engine looks good, bet it's good to have that bit of extra power.
It will be great to see it in the flesh at one of next years shows.
8)
Having already booked some time and space with Clem at his workshop for him to carry out both an internal and external waxoyl treatment, it seemed a great opportunity to try and improve the sound deadening. Ordered some Second Skin Damplifier Pro and a tub of spectrum spray from Car Audio Direct (great service from these guys by the way)
The difference to the doors alone is amazing - and to paraphrase the current VW tv advert when you now shut the door it almost sounds 'just like a golf' It may cost a bit more but I have no worries about moisture build up and that is great peace of mind for a bus that has spent the first 39 years of its life in a sunny clime and just one adapting to our UK weather.
Driving the bus home tonight there is a real difference to the front of the cab, and I've just got a bit of finishing off with some Second Skin Luxury Liner Pro internally over the rear wheel arches and the engine fire wall. These were areas that I didn't want to cover up with a sticky back material as the original paintwork is so good, so a bit of a compromise but the liner pro should help but have to accept it really should be stuck down.
Mike and Paul took great care taking out the westy furniture and it was an ideal time to vacuum up a good few years of red dust that had found its way into the smallest spaces. As you will see from the photos the internals in the bus are every bit as good as the externals
There were a few South African coins hidden in the dust and a few cigar stubs showing that the bus has always been 'enjoyed'
Everything was then carefully resealed, door cards replaced and everything bar the dust and dirt was replaced just as it was found. Even the side window behind the wardrobe was cleaned up before the westy curtain was replaced.
The underside and the rails were all fully treated with waxoyl which will aid what looks like factory applied underseal which has stood up pretty well so far
Knowing Mike's love of collecting original curtains I did do a quick count up, but all went back up :lol:
Its ready for the next 40 years now, but the proof will come on the trip to Ninove as to how much quieter it is on the road. Should mean able to have conversations not shouting matches, but not at the expense of missing out on that unique engine noise - its still there
Next step before Ninove is getting the engine set up properly, and taking Easy's advice its booked in with Jason at Interpro in Thornbury to get the new engine and weber 34's working together more in harmony than they are now
What I would say, if you are considering taking advantage of Clem's waxoyling service and don't have the time or the facilities at home to carrying out the work yourself, it is money well spent. The care taken is tremendous and you have a clear idea about what it is going to cost based on his well thought out modular charging system depending on what you want carried out. But be quick as space in his diary is filling up quickly
David
As a westy pervert, it was a pleasure :)
I’d been searching for one of theses for a while because the Punch & Judy style didn't seem quite right with a South African bus. From what I could find out people like VW SA 'sold' kombi awnings via their dealerships or other were made by Durban Tent and Awning Company. But are pretty hard to find these days, spotted this one on the equivalent of SA Ebay back in November and when it didn't sell approached the owner and did a deal. It eventually arrived 2 weeks ago and had its first outing in the New Forest last weekend. Designed really for a tin top or even Type 25s it has an awning for the bus as well as for people and access is via the rear flap in line with the sliding door.
Really well made, but a heavy canvas and an even heavier bag of poles! Gave it a good check for spiders and other creepy crawlies as it was being put up for the first time.
Hi david, I like it. 8) 8)
Even got a cover for the Bus. :D
Good to see you out and about using your bus already.
Si
OK this may not be the prettiest location, or even the best photo of my westy after it has been scrubbed and polished but its a special shot for me as two months to the day since it broke down in France and the horrors of it being hit in the recovery company's storage facility in Dover I was able to go and collect it and drive it home from Java VW after Jonny Abbott and his guys had worked their magic over the past few weeks. Must admit it felt good to be driving the westy back across the Cotswolds again with a smile on my face
The Return by cotswoldiver, on Flickr
They replaced the bottom half of the rear corner with another original panel acquired from a donor van so at least it has almost kept its originality there, but the paint match which I was more concerned about is spot on.
Once again I had the dilemma of someone wanted to buy the bus, but as I didn't really want to sell I asked a price above current market price and thankfully after they considered it they told Jonny no, so now its back to enjoying it as it was intended and its off for a week's holiday camping in Dorset with the family next week - if I can solve a generator problem that has occurred again, details of that in a cry for help in the technical section
Tempting as it was to sell (just for a few minutes ;) )and use the cash to start a project from ground up, at the moment I'm really pleased it is tucked up safe and sound in my garage and the adventures can continue :D
Thanks guys
As a bonus, thought we may also have solved the paint code and colour as well - looks like it may be L10H which is Arizona Yellow on some listings. Certainly fits in with the green/yellow hue but when I've searched for that colour on an early vw beetle it looks a bit too yellow and not enough green - maybe Beryl Green is closer? Or may be there is an Arizona Green somewhere that is a mix of both :?:
The 'shiney shiney' has been a lot of hard work over time sometimes by hand and other times with a DA machine which doesn't get the paint surface as hot as a rotary machine. Using clay with Dodo juice born slippy lub to pull away a lot of the contaminates and then Dodo Juice prime light to clean up the paint work as it doesn't have any harsh abrasives in it. Great stuff Dodo juice and smells real good.
Because the paint layers are pretty thin most of the specialist polishes and cutting compounds are too harsh and could remove too much paint so I've found another company called Gtechniq http://www.gtechniq.com/shop/3s-for-cars/ who makes some pretty amazing products for both polishing and protecting paint and other surfaces. The way water beads off the surface is amazing
Its now getting to the point where people think it has actually had a full respray and can't believe its still the original paint - well except for the bottom rear corner now - :cry:
Anyway, enough of the cleaning mumbo jumbo time to enjoy using it...
