Routing fuel lines help
thejinx
Mar 30, 2011
1,559
73
swansea
As it says really where to route the fuel cable. I have renewed the hose from tank placed a fuel filter on the pushed the line through the bulk head on the left side as your looking from the rear. Does it now come over the fan housing past the coil and onto the fuel pump. That doesn't look right to me. Any help with pics would be brilliant thanks
Noooo! Don't route it over the coil. If you get a fuel leak that could be very dangerous indeed!
It should go around the side, underneath the heater tubes (from fanshroud to heat exchangers), past the dizzy to the pump. I'll try dig out a picture to illustrate.
Image from TheSamba
Image from PakWheels.com
Cheers fellas. Here's another. :msn4: the Hainse manual says the inlet for the fuel pipe is on the bottom and outlet top. That doesn't seem right. Any ideas
