I have just swapped out my dynamo for an alternator, part of the bundle kit also included a fuel pump and fuel push rod. Therefore, I had also swapped out the fuel pump and used the fuel rod provided with the kit (it was slightly shorter than the one I had with the original fuel pump.
I had to remove the carb to get the dynamo out. Everything was put back in place and she started first time. I then tested the battery with a volt meter and then tested the voltage from the alternator with engine running, all seemed okay and alternator was charging battery fine.
Tools packed away and I thought of going on a small trip to ensure all was well. Unfortunately I never got of the drive, she just cut out.
She will start after a while, but will stall again after running for a few mins.
Any ideas as to what the issue might be?
