Bodywork well on and hopefully in paint in a couple of weeks.
Now turning my attention to running wires in ready for wiring in leisure battery, fusebox and 240v supply. Like an electrician would first fix a house is what I'm after doing before putting head liner, cards and floor in.
I need to run a wire from LB to fuse board which I plan to put under r n r bed. That is also where the consumer unit will be. So the plan was to run the live wire from lb. Up through hole in spare wheel well, under rear cushion and down to fuse board. From fuse board I want to run the main interior light, 2 led spot lights under the overhead cupboard, a 12v supply cig lighter socket and my radio. I tried to run cables for the lights and radio down the c pillar and come out where the panel card will be and straight to the r n r bed but cannot get a cable down there, even when using a proper cable pull. I can run the cable for the radio under the floor but the lights need to run along the inside of the roof. I also need to run a flex from the consumer unit to two twin sockets, one to be in buddy seat and other in a home made unit where the wardrobe would normally go. Again I wanted to run this in the roof and drop,down to the sockets coming out through the panel cards.
So can anyone give me some idea how you have run your cables to feed all the auxiliary bits and bobs?
