Shoddy
Hi
I'm building up to stripping out the insides of my bus this winter and thought i best stick some sound deadening material etc in before new headlining / panels / floor. Seen a quite a few recommendations for the silentcoat so happy to just go with that. Looking for some tips/advice on coverage though .....
1. Would you cover the entire roof in this?
2. Load area floor ..... removed the orig old hardboard sheet and strips of black stuff? Would you cover the whole area or just strips like it had before? Thinking I'd put a bit of carpet down on top before R&R cushion etc.
3. Cargo floor.... again, cover the entire floor or just strips? will be putting down ply then vinyl ultimately
4. Cab floor....sticking with a standard black rubber mat. is it worth coating under here?
5. Panels ....stick pieces on the areas you can get to?
Think the bulk packs are circa £85. Interested to know what others have done and how many packs they went through.
Cheers for any help
Craig
Cheers for any help
Craig
